- Color and Monochrome are now separate installations - The PowerVision Development Studio executable has now been split into two separate installs.
 - Loader Graphics (Color M2) - Graphics for the M2 Bootloader screens have been altered to eliminate color and minimize branding.
 - Support for 64bit on Windows 10 - When running on 64bit versions of Windows 10, the installer will configure PowerVision to run as a 64bit process allowing larger memory support.
 - QR Code Image Widget on M2 (Beta) - This release introduced beta support for showing a QR Code from a Reserved String.
 - Menu Editor (Mono) - We have Added support for directly editing variable values from the menu editor.
 - Failsafe M2 Loader (Color M2) - Allows the loader to load a file even without a functioning input method.
 - Bugs Fixed in this Patch – The following were some of the bugs fixed in this Patch.
- Fixed an error when configuring Analog Curves.
 - Fixed an error with negative numbers and leading zeros on text gauges.
 - Fixed support for PAL video in M2 Platform Video Widget. The system was not correctly deinterlacing the video.
 - Fixed a problem with Activity Programs using Float instead of Double for math operations which resulted in data truncation/rounding in large numbers.
 - Added support for RTC clocks to M2 hardware platform where applicable.
 - Fixed an issue with AngelScript using the incorrect path for file based functions.
 - Fixed issues with List widget that could prevent the list from being scrollable or selectable in rare situations.
 - Fixed a problem with Touch and Key process priorities that would cause sluggish performance in high CPU conditions.
 - Fixed a rare bug in that could crash the programming module when the first event (Event ID 1) in the system is triggered.
 - Fixed bug with boot logos that could crash display if a logo is added that is larger than screen size.
 - Fixed bug with smWrite() in scripting.
 - Fixed clipping problem with drawing in iMX35 that could cause screen artifacts on larger or italic fonts.
 - Fixed a few areas where the new “Find All References” would not return results.
Download PowerVision for Controllers 2.9.21075
For up to date literature about the MPC-20/MPC-20r2, MPC-10/TEC-10, please visit the product pages at http://www.enovationcontrols.com
