I have a customer that gets a DM message, SPN5610, after diconnecting and reconnecting the display. There is a battery disconnect on the truck that is used to save the battery if the truck isn't going to be used for awhile. I use the internal resistor in the PV750 for termination and I am wondering if the resistor is not active fast enough, causing an error?
I have the J1939 documentation (-71 and -73) and there is no mention of SPN5610. The display indicates transmission device as the source, but the tranny documentation also does not list SP5610.
Any ideas?
SPN 5610 after disconnect
- drphil69
- drphil69
Re: SPN 5610 after disconnect
Oops, the SPN is 5160, not 5610...
Hello drphil69,
Here is what I what found on SPN 5160.
Name:
Auxiliary valve number 0 measured flow limit status.
Description:
This parameter is used to report the tractor ECU’s present measured flow limit status associated with valve number 0 flow commands that are persistent.
Name:
Description:
