DM14 implementation
ShrutiK
DM14 implementation
Post by ShrutiK » Wed May 18, 2011 6:04 am
Is there any Dm14 implementation available to calibrate any parameter using J1939 "Memory Access Request message"?
Thanks & regards,
Shruti
Re: DM14 implementation
Post by ksaenz » Mon May 23, 2011 10:21 am
Hi Shruti,
In the Environment Setup section, select the device in the CANPort you want and then select DM Memory Mapping, it is in the same bar as J1939/NMEA Parameter Mapping and DTC Mapping.
