Good mornig,
After a wrong programmation, I can not load a program ine a PV350.
With the other product, I can use the "USB way".
But whith this new device with 1 CAN port, How can I reset a module PV 350 to the original version ?
Thank you for your tips
Sylvain
PV3xx : Reset
- Tremouilhac
- priyauplaonkar
Re: PV3xx : Reset
PV350 is programmed using the CAN port. You can use the Powervision Configuration tool to program it.
Below are he steps:
1. Make sure the unit is in the OFF state.
2. Now hold the first button(Left most) and the fifth button(Right most) simultaneously and turn on the unit while you are holding these two buttons.
3. You are now in Boot Loader mode. It displays the Boot loader version on the screen.
4. After doing this, you should now be able to see the load button on your Powervision Configuration tool.
5. Load the required configuration.
For Installation and Operation instructions you can refer the manual under the below link.
http://www.fwmurphy.com/products/displays/pv350-380
PUplaonkar
Below are he steps:
PUplaonkar
- priyauplaonkar
Re: PV3xx : Reset
Also, You can order the ECom Dongle that is used to program the PV350 via CAN.
PV350/380 Programming Kit (P/N: 78-09-0100) which includes:
• E2046004A ECOM Dongle J1939 (locked)
• 78-00-0702 Power/CAN Harness, 6-pin Deutsch
• 00-00-9510 Y, 3-pin Deutsch
• 00-00-6408 120 ohm Terminator, Deutsch
• 00-00-0386 Power Converter, AC/12VDC
• 00-00-0388 Power Cord, 120 VAC
If you already have an Ecom dongle (locked or unlocked), you can individually order the P/N within the kit.
Hope it helps.
PUplaonkar
Hope it helps.
PUplaonkar
