Page Designer Tutorials
- dberezowski
Page 40 of the Configurator 2.1 manual states "NOTE: A set of tutorials are available that will walk you through the setup of the Page Designer. This can be found in the system's Help files." I have been unable to locate these, where can I find them?
- jpurdum
Re: Page Designer Tutorials
To get these tutorials (Warning - about 400MB in size), please go to this post:
viewtopic.php?f=5&t=56
- dberezowski
Might I suggest that the tutorials also include a "completed" version of each tutorial ( perhaps by appending completed to the configuration name ). This would allow a user to see what the final result should look like when downloaded to the PV750. They could then compare it to what they created. Also, the tutorials occupy the entire screen, so unless one is running two monitors, one cannot watch the tutuorial and make the changes to the Configurtator at the same time.
- jpurdum
If you look in the db3s directory in the package you downloaded, you should find exactly what you're looking for... For each example config that gets modified there should be a Completed config...
- dberezowski
In the "Custom page Flow" tutorial, the blue PopUp error button is on the Overlay layer and the "Fuel Level" menu/overlay is on the Pop Up layer. This seems backwards.
dberezowski wrote:In the "Custom page Flow" tutorial, the blue PopUp error button is on the Overlay layer and the "Fuel Level" menu/overlay is on the Pop Up layer. This seems backwards.
It is a little backwards. There was a bug in the pre-release 2.0 that probably have affected this tutorial. We will get the layers switched around for the next release.
