I am having a problem getting Key Repeat to work on a PV750.
I have 2 variables set up with up/down buttons. Everything is identical (as far as I can tell) except for the variable names, including the calculations. Out of the 4 buttons with Key Repeat, 3 of them work fine, while 1 will only do the Key Down event.
I can send the config file if needed.
PV750 Key Repeat issue
- drphil69
Re: PV750 Key Repeat issue
Ok. If you send it to me, I'll try to help.
