Checking DTC Data for null
cconner_aie
Post by cconner_aie » Thu Oct 19, 2017 7:44 am
I have a function that catches new DTC's and saves them to a historic list internal to the panel and I've run into problems with the panel locking up.
I've narrowed it down to the Fault Description and Action Description fields. If I read these fields:
J1939DTC dtcData;
ListManagerGetItem(ListDataType.Dm1ListType, i, dtcData);
string actionDescription = "";
dtcData.ReadActionDescription(actionDescription);
string faultDescription = "";
dtcData.ReadFaultDescription(faultDescription);
CustomListData listData;
listData.WriteString(CustomListColumn.HistoricFaults_ActionDescription, actionDescription);
listData.WriteString(CustomListColumn.HistoricFaults_FaultDescription, faultDescription);
ListManagerAddItem(ListDataType.HistoricFaults, listData);
When action description is null (if there isn't a DTC in the library), the panel will lock up. I can tell it's null because I see garbage when remotely viewing the list, it looks like the string is not terminated and I catch random bits of memory.
This has been pretty consistent with the action description, so I removed it. However I just started to see the same behavior with fault description, even when the string is empty rather than null.
It doesn't appear that I can do a simple 'if (actionDescription == null)' check with how strings are implemented. Is there a good way to check that the data in J1939DTC is filled?
I'm currently on 2.9.20040 using a PV480. We are trying to wrap this up this week and this just became a bigger issue, so if there is any advice I'd greatly appreciate it.
Coleby Conner
Re: Checking DTC Data for null
Post by boyce » Thu Oct 19, 2017 8:17 am
I'll put a bug in the system to get more people looking at it. Can you private message a configuration to me that can reproduce the error and the information about the DTCs that cause the problem?
cconner_aie
Post by cconner_aie » Thu Oct 19, 2017 8:19 am
Thank you Boyce, I'll try to put together a watered down example to send you.
Coleby Conner
