I tried to use a smart label to display a J1939 message from the transmission - Current_gear. This reports the gearbox status as follows:
Reverse1: -1
Reverse2: -2
Reverse3: -3
Neutral: 0
1st gear 1
2nd gear 2
etc., etc., and these figures were entered in the selector value field.
The smart label Display value should have read:
R1
R2
R3
N
F1
F2
F3
However, the display only shows the enumerated values from zero upwards it will not enumerate the minus figures.
V2.7.10475
PV780
Using Windows 7
Smart label selector values & minus figures
- Multidrive
Re: Smart label selector values & minus figures
Hello Multidrive,
Thank you for mentioning this. The bug is that you were able to enter a negative number for an enumeration value. The enumeration variable is an unsigned int.
In 2.8.10366, you aren't able to enter a negative number as an enumerator.
Sorry for the confusion.
