Would you advise if I can change the PV380's I/O pins configuration by using PowerVision?
For example, I would like to increase AI and DO instead of sender input. Please refer to the attachment.
If it is feasible, would you instruct how can I do this?
Thank you.
Akihiro Kobayashi
Kimura Corporation
Changing I/O pins
- Akihiro Kobayashi
Changing I/O pins
- 170117.pdf
- (218.32 KiB) Downloaded 8 times
Akihiro Kobayashi
Kimura Corporation
Kimura Corporation
Re: Changing I/O pins
It is not possible to change the PV380 I/O pins. Those I/O pins can only be resistive inputs and they can not be configured as digital output or analog inputs.
- Akihiro Kobayashi
Hello Boyce,
Thank you for the explanation.
I understand that we cannot change the I/O pins.
Is it same for PV450 and PV780?
Thank you.
Thank you.
Akihiro Kobayashi
Kimura Corporation
Kimura Corporation
Yes, the PV450 and PV780 are the same. The PV450 has less I/O and the PV780 has the same number of analog inputs and digital output. The PV480 is an OEM display that has 4 analog inputs and 4 digital outputs. I don't know if Kimura has an OEM relationship, you can look at it to see if it meets your needs and speak to your marketing representative.
