reading the spec for the digi outputs, there are only 2 types: (500hz and 100hz) is the J6 2 way connector ( DO 11 & 12) actually different? Why does it use much larger pins than can take more current?
Connector J4 - Black 1 Digi Out 1 15 A (PWM @ 500 Hz)
Connector J4 - Black 2 Digi Out 2 15 A (PWM @ 500 Hz)
Connector J4 - Black 3 Digi Out 3 15 A (PWM @ 500 Hz)
Connector J4 - Black 4 Digi Out 4 15 A (PWM @ 500 Hz)
Connector J4 - Black 5 Digi Out 5 15 A (PWM @ 500 Hz)
Connector J4 - Black 6 Digi Out 6 15 A (PWM @ 500 Hz)
Connector J3 - Grey 3 Digi Out 7 15 A (PWM @ 100 Hz)
Connector J3 - Grey 4 Digi Out 8 15 A (PWM @ 100 Hz)
Connector J3 - Grey 5 Digi Out 9 15 A (PWM @ 100 Hz)
Connector J3 - Grey 6 Digi Out 10 15 A (PWM @ 100 Hz)
Connector J6 2 Digi Out 11 15 A (PWM @ 100 Hz)
Connector J6 1 Digi Out 12 15 A (PWM @ 100 Hz)
many thanks, Dave.
PDM digital outputs
- embtechnicalservices
PDM digital outputs
http://www.emb-technical-services.co.uk
Windows 10 Home x64 - PowerVision 2.9.21075 OEM
i7-7700HQ ,16GBRAM, 500GBSSD, DELL Inspion 7567, 4K UHD Display.
Re: PDM digital outputs
Hello embtechnicalservces,
The pinout in PowerVision Configuration Studio is just for information. You need to look at the literature for the IX3212 here. The Reference Manual shows more information.
