Updated a PV780 program to 2.8.10546 cannot read some free form messages
dwatson
Post by dwatson » Fri Jun 02, 2017 10:54 am
Application was updated from 2.8.10356 to 2.8.10546 and was unable to read some of the free form CAN messages. Reloaded a full install from 2.8.10356 and the messages were read.
When the message was deleted and added again it them showed receiving the message.
The are a large number of messages - do we need to verify each one is correct or is this a know issue was a way of addressing?
Re: Updated a PV780 program to 2.8.10546 cannot read some free form messages
Post by boyce » Fri Jun 02, 2017 11:13 am
Sorry that you have run into a problem. This is not a known issue.
Is it possible for you to send me the configuration in a Private Message? We will take a look to see what the problem is.
alb
Post by alb » Thu Jun 22, 2017 1:00 pm
Double check Data Lengths in FFCAN Message Definition. Newer versions of PowerVision are no longer Data Length-agnostic and will filter out messages shorter/longer than the FFCAN Definition.
