Hi all i have 4 projects here in south africa what i am working on but im batteling with the one the customer wants the following specs:
1. 60+ usernames and passwords for his technicians on the mine i've got that in a csv file.
2. If there is a shutdown on the machine and the technician puts his username and password into reset the machine that it saves his username and also the fault codes which is reset.
3. Then say once a week that you can download it to a flash drive to view on a laptop or pc for the use in there meetings.
Username saving
- ECS-SA
Re: Username saving
Hello Marcell,
1. You can copy a file from a flash drive to the PV450 using the functions mountUSB(), copyFromUSB() and unmountUSB() in a script. Instead of storing the username and password in the file it would be a good idea to store the hash value of the unsername & password.
2. When there is a shutdown, a script can write the username used and athe fault thas was reset to a file using the open() writeString() and close() methods of the file object add-on.
3. To download the file to a flash drive you can use the functions mountUSB(), copyToUSB() and unmountUSB() in a script.
