When using PowerVision 2.8.10315 I have discovered that if all of your items are not mapped or your configuration is not valid, that when you try to refresh the data size bar the program crashes. I have verified this by having my configuration 100% validated and refreshing the data size bar with no error, then going into the programming tab and removing a link between a multi decision and a set variable. When the data size bar is refreshed the program crashes with the error message : Object reference not set to an instance of an object.
Thank you
Mike McKinnor
Version of Configuration Tool: 2.8.10315
Model Number of Unit : PV380
Operating System: Windows 8.1 64bit
2.8.10315 Data Size refresh crash
- MikeM14
Re: 2.8.10315 Data Size refresh crash
Thank you MikeM14.
I have recreated the problem and we will get it fixed!
