pv450+ESF INPUT
- pfu
pv450+ESF INPUT
I got a application that PV450 will input fuel level by ESF . You know the ESF that 240ohms means empty and 33 ohms means full. I have got a case from forum, and flash into PV450 for test, but i find the data is not correct. when 33ohms, i got 78 raw analog input and 0% fuel level; when 240ohms, i got 384 raw analog input and 82% fuel level .It seems they are reverse. so who can help me ? the attachment programming is correct?
- Analog Input Fuel Level.db3
- (2.96 MiB) Downloaded 12 times
Re: pv450+ESF INPUT
Hello pfu,
When did you download that configuration?
That configuration has an incorrect conversion table but it should have been replaced with the correct conversion table.
You can correct the table in the script manually or download the new configuration.
// Fuel sender table
uint[][] es2f = {
{ 66,100}, // tolerance
{ 81,100},
{ 110, 90},
{ 136, 80},
{ 162, 70},
{ 186, 60},
{ 211, 50},
{ 243, 40},
{ 271, 30},
{ 308, 20},
{ 348, 10},
{ 385, 0},
{ 403, 0}, // tolerance
}; // raw, percent- Attachments
- Analog Input Fuel Level.zip
- Created with PVCS 2.2.10678
- (1.95 MiB) Downloaded 23 times
- pfu
Re: pv450+ESF INPUT
HI Ksaenz,
I download this program from below website: viewtopic.php?f=7&t=434&p=1136&hilit=ES2F#p1136.
I will try this new program.
Thank you ,Sir
Peter Fu
Thank you ,Sir
Peter Fu
