Welcome
Please help to configure the RTC in the PV780.
I tried to use RealTimeClock.SetMinute + 1, but does not work.
Thank you for your help.
Łukasz
Set RTC in PV780
- ZDPIMB
Re: Set RTC in PV780
Hello ZDPIMB,
You are making a good start. It is always easier for me if I can see an example.
Look in the Murphy Standard PV780 config that is provided with PowerVision Configuration Studio.
In this config, a variable, TimeInSeconds displays the time. TimeInSeconds is based on the RealTimeClock.Hour and RealTimeClock.Minute System variables.
In the Programming tab, look under the Custom - Display Selection. Look at how the TimeInSeconds and TimeInSecondsSet get used. The event, Update Clock and Restart, will cause the RTC to be updated. It might cause a reboot also.
Letting the user set the clock is on the Menu Layer.
Hope this helps! If you have more questions, please ask.
