DM1 New Fault Available
SaraBerglund
Post by SaraBerglund » Mon Dec 20, 2010 9:14 am
Does anyone have any additional information that they could share on the transition "DM1.NewActiveFaultAvailable"?
I have a simple page change that is triggered by this transition, but the page changes even if the DM1 message is blank. I have also tested this with the Standard Configuration, which uses the same transition, but there is no page change when a blank DM1 message is received. Am I missing an extra step that is required?
Thank you!
Sara
Re: DM1 New Fault Available
Post by ksaenz » Tue Feb 22, 2011 11:52 am
When you say "blank" DM1 message do you mean SPN 0 FMI 0?
In the Standard Configuration's DTC database SPN 0 FMI 0 has a checkbox to be dropped and that would prevent it from triggering DM1.NewActiveFaultAvailable.
