I just uploaded a program to a HVS 450 and I got this message:
Invalid configuration version: 0
Application version: 2.3.10155.0
Required configuration tool version: 2.3.11073 to 2.1.11500
Since this message is displayed,I have not been able to reconnect to the device
What should I do?
Charles
Invalid Configuration
- cmassicot
- jbilleter
Re: Invalid Configuration
I'm not 100% sure this is the reason, but have you updated your loader with the latest from this post?
viewtopic.php?f=3&t=757
Once you have confirmed that the reliability update is done, try it again and see if it will load into the PV450. Good luck!
Jacob Billeter
Staff Engineer - MurCal, Inc.
- jbilleter
Which version of PowerVision are you using? Have you upgraded to the most current? I would also upgrade to the most current version and see if that corrects the issue.
Jacob Billeter
- cmassicot
I am using PowerVision 2.6.20023
I will update the bootloader from the post you mentioned and see if it helps.
Charles
Charles
Definitely update the boot loader. Also make sure you have created a "FULL" install and loaded the display. This message usually means you have a Full install of one version (Apps) and a "Config" install of the configuration (Config).
To get it working, you can pull up a known working configuration such as "Blank" and generate a "Full" install. Save this to a thumb drive and load it directly. After that you should have your connection to the PC restored.
- cmassicot
Problem solved, thank you for the quick reponse.
Charles
Charles
