Digital Output
- Esb1983
Digital Output
Hi
I need an example for PowerVision 2.7 that uses a button to activate the digital output to an adjustable level for the PV450.
Regards
Regards
Re: Digital Output
Hello Esb1983,
There isn't much to this, one button for on/high and one button for low/off.
- Esb1983
Re: Digital Output
Hello
This message appears when try to open ·
"Selected Configuration is newer than the aplicattion version "
"Can not open confuiguration"
My PowerVision Configuration Studio(Released Build)
Build: 2.7.10439(6/30/2014)
Part Number: 78-33-3154
Re: Digital Output
Hi Esb1983,
The config was built with the 2.7 Patch 4 Release of PowerVision Configuration Studio found here. If you are an OEM user, you should find a Patch 4 Release in the OEM forum.
Thanks! Please let me know if there is anything else I can help with.
- Esb1983
Re: Digital Output
stalley wrote:Hi Esb1983,
HI
Need to increase the voltage from 0V to 5V with each press, step by step, I'm testing but I get up the voltage of the digital output, you could use the output PWM controlling it
Thanks Sara
Re: Digital Output
Hello esb1983,
A digital output is going to be "ON" closed to ground and "OFF" open to ground, as implied by it being a digital output.
Are you asking about the frequency output on a PV780? If so, there is a forum topic viewtopic.php?f=7&t=1022&p=2890&hilit=f ... tput#p2890 that has some information about the frequency output.
What product and output, specifically, are you asking about?
- Esb1983
Re: Digital Output
Histalley wrote:Hello esb1983,
My product is PV450 and output digital
- Esb1983
Re: Digital Output
Hi
As I can control the duty cycle of the digital output of pv450, to control the level of voltage.
Regards
Regards
