DM2 Function on PV750 and PV450
tshiii
Post by tshiii » Mon Jun 23, 2014 4:39 am
Dear Sir,
<PV750>
1) How many items of DM2 can be listed in a display?
2) If DM2's are occurred in excess of the above 1), how are the DM2's displayed?
<PV450>
Thank you and best regards,
Shiii
Re: DM2 Function on PV750 and PV450
Post by stalley » Mon Jun 23, 2014 8:35 am
Hi Shiii,
What version of PowerVision are you using? 2.3, 2.6 or 2.7? With all versions of PowerVision, you can open a Murphy Standard Configuration for the color displays. These configs have screens and state machines to retrieve and display the DM2s. I would recommend looking at these configurations to see how to display multiple fault codes. There are also example configurations on this forum that might be helpful.
In the PowerVision 2.3, the Diagnostic Messages application is found on the Environment Setup tab.
In the PowerVision 2.6 and 2.7 the Diagnostic Messages application is found on the Applications tab.
The PowerVision manuals are also available to you on this forum.
Both the PV450s and PV750s can store up to 55 DM2s in memory to be displayed. If the ECU has more codes than 55, you could use the engine's diagnostic tool to retrieve all of the codes.
Thank you for your interest in PowerVision!
