Hilight Control of USER SETTINGS
mcg2068
Post by mcg2068 » Thu Oct 27, 2016 10:15 pm
The highlight (yellow box) behind the Settings to change in PV450 and the settings.
How is this box controlled per screen? All screens are same, still each has its own yellow box and item to change.
thanks.
Re: Hilight Control of USER SETTINGS
Post by stalley » Fri Oct 28, 2016 7:47 am
Hello mcg2068,
I'm guessing you are asking about the PV450 standard config that comes in PowerVision Configuration Studio? Is the version of PowerVision where the configuration came from a 2.7 or 2.8? The configs from the previous versions of PowerVision are controlled differently, please let me know if you are asking about a different configuration.
In Programming, if you search for the widget name, User Settings Highlight, you should find all of the events used to control the widget. It is an example of controlling a screen object rather than having multiple Image widgets which use a lot of memory.
Thank you for your interest in PowerVision Configuration Studio! We have spent some time developing the standard configurations provided with PowerVision using different capabilities of PowerVision. The standards are great to use as examples when developing your own configurations.
Best Regards,
mcg2068
Post by mcg2068 » Wed Nov 02, 2016 11:11 pm
We are using 2.8.
mcg2068
Post by mcg2068 » Wed Nov 02, 2016 11:12 pm
We are using 2.8.
We found it in advanced settings.
Smart !!!
THanks for your support
