Transition Timer
mwalker
Transition Timer
Post by mwalker » Thu Nov 18, 2010 10:17 am
Is there any way of showing the value of a timer that is on a transition?
jpurdum
Re: Transition Timer
Post by jpurdum » Mon Nov 22, 2010 6:18 am
Well, not directly anyway. If you're looking for something like a count-down timer, let's say for 10 seconds, set up a state with a transition on a 1 second timer. With that you should be able to increment a counter that can display on the screen. You would check with each transition to see if the counter is equal to 10 at which point you would quit.
Is this the kind of thing you're trying to create? If so, let me know if you'd like to see an example.
