When using unit conversion, decimal places are being rounded. For example, I am recieving 58 degC from the J1939 bus (intake air temperature). When displaying the parameter in a text gauge with units of fahrenheit with decimal place set to 1, 136.0 degF is displayed. The actual displayed value should be 136.4 degF. With 57 degC, the display is rounded up to 135.0 degF instead of 134.6 degF.
The errors get really large when converting from kPa to Bar.
Bug: Rounded decimals with unit conversion
- mbowdich
- bseidl
Re: Bug: Rounded decimals with unit conversion
I tested this out using your example of the intake temperature. If I change the "Small Increment" property of the text gauge to 0.1, then the gauge displays the correct converted value (i.e. 134.6). You may want to make sure the "Small Increment" property is set correctly to match how many decimal places you want to use.
Brad Seidl
F.W. Murphy
Brad Seidl
F.W. Murphy
