I've been doing the bar color change with using 2 bars till now. However it can't meet some of the requirements.
What I'm trying to do is, showing the bar fill with red color till 50% after that, the color should change to blue. I've been using identical bars on top of each other, displaying the same data till the 50% mark. When it is reached, red colored bar is hidden and the other one is shown. However, the animation is cut in middle when the data jumps over or down at that mark since i'm using 0,1 smoothing for the bar. (For example: data is sent over CAN so when the screen turns on it may be at 80%, I want it to start at 0 and fill up to 50% in red color then switch to blue till 80%.)
Using the animatecolor action changes the color of the ticks of the bar gauge, not the data that fills the bar.
Is there a way to accomplish this? I hope I have stated the issue clearly...
Mert
How to change bar gauge display bar color?
- nms
Re: How to change bar gauge display bar color?
I don't see a way to control the color of the bar gauge with the AnimateColor action. To do what you describe could be done with the stacked bar gauges but by controlling the value instead of displaying the CAN parameter. You would calculate the value to display and set the visibility for the desired bar color. I don't think it would be as smooth as a bar gauge with smoothing but you could try it.
- nms
Thanks Boyce,
I'll give it a try.
I'll give it a try.
