This is more of a hardware question than PowerVision question.
On the MPC-10, what is the range the analog inputs can accept, when used as a restive input?
I have an application looking to use a 0 - 10,000 Ohm sensor and I would like to know if the hardware can handle that resistance range. I understand that the F.W. Murphy standard configuration does not support this kind of sensor, and the configuration would have to be modified to handle that.
I took a look at the addendum section of the IO v2.8 document and was unable to locate this information.
Let me know, thank you
MPC-10 Analog Input Range Question
- Ocelot
Kyle Bruneau
Re: MPC-10 Analog Input Range Question
Hello Ocelot,
The MPC-20/-10/Tec-10 can handle the 0-10000 ohm input range.
Using the full PowerVision Configuration Studio, you can add your own input curve/input definition or modify one of the existing definitions.
