I found that bar graph control doesn't accept any decimal min.- max. range value (0 - 0.7). It allows the range only in terms of whole numbers (0 - 7).
Can't we give decimal range to bar graph?
Thanks and regards,
Shruti
Assigning decimal range to bar graph control
- ShrutiK
Re: Assigning decimal range to bar graph control
Hello Shruti,
Thank you for your feedback. We will consider this feature for a future release.
In the meantime you can look at the attached configuration for an immediate solution.
The example has a new unit conversion equal to the original unit multiplied by ten.
On the screen there is a text gauge that displays the value in the original units and a bar gauge that displays the value in the multiplied units.
- Decimal Bar Graph.zip
- Created with PVCS 2.3.11157
- (115.54 KiB) Downloaded 13 times
