Internal DM1s
ECS-SA
Internal DM1s
Post by ECS-SA » Wed Jul 18, 2012 6:11 am
Hi all,
can someone help me i would like to know how can you create internal Dm1 messages for analouge inputs into the displays if this is possible can someone please assist me with this.
Thank you
Harish
Re: Internal DM1s
Post by Harish » Thu Jul 26, 2012 5:08 pm
Marcell,
Please see the attached config which shows an example of how to create an internal DM1 message. In this config, an internal DM1 message appears on the display when the Engine speed exceeds 500 RPM. Further, the Engine RPM is tied to the Analog Input (Resistive). So when you vary the resistance, the Engine Speed changes and a Diagnostic message is created when the speed exceeds 500 RPM (configurable). In this example, the Engine RPM is directly based on the raw A/D count of the Analog Input. However, you can use any other standard sender table for this. Hope this is clear.
Thank you,
Harish Gadigota,
Software Test Engineer,
FW Murphy, Tulsa.
Internal DM1 Feed using Analog Input PV450_2.3.zip
Config
(1.7 MiB) Downloaded 39 times
