I am new to PowerVision, working on my first project. Started with a Blank configuration for PV780 and I am preparing for analog input configurations. Going to the "Pre Defined Curves" tab I am greeted with a blank "Curves" panel; there is no pre-defined curves anywhere at all.
Is it because I started with a blank copy? Can I import the curves or I need to re-start with a different template?
Thanks Peter
Pre Defined Curves
- PeterV
Re: Pre Defined Curves
Yes, the blank configuration does not have any Pre Defined Curves defined. The curves will have to be defined in this case. It might be just getting the list of points to define the curve. I even looked to see if there was an export and import in the configuration components but no.
- PeterV
Thank you!
