Temprature Differences
ECS-SA
Post by ECS-SA » Tue May 03, 2011 5:17 am
Hi All,
Please can you guys help me is it possible to messure a input and output value of a radiator with two temp sendors but if there is a differance on the tempratures that have a differance of +- 5 to 8'c that we can have a warning on the displays by using the xm500 for the configuring of the temp sensors
jtabb
Re: Temprature Differences
Post by jtabb » Tue May 03, 2011 5:05 pm
Marcell,
Yes, that is a possible configuration. The XM500 can be configured to compare two temperature sensor inputs. It will have to be a custom configuration on the XM500 and then the display will be configured to receive the warning.
I hope that answers your question.
jtabb
jtabb
FW Murphy Development Team
ECS-SA
Post by ECS-SA » Wed May 04, 2011 2:22 am
Is there maybe an example of a configuration i can get that will give me the output then as a switch to put a light on on the pv750
thanx
marcell
jtabb
Post by jtabb » Thu May 05, 2011 8:29 pm
I don't have an example configuration to give you for the XM500. If there's an applications engineer or marketing manager you work with he may be able to assist you with that. It should be a fairly straight forward configuration.
On the PV750 you would just need to display a gauge when the SPNS are received and display the DTC sent from the XM500. The gauge should be easy to configure and the DTC processing will already be done in the PV750.
jtabb
jtabb
